Background app refresh - Required?
I know that Scenic requires access to location info, so I have that turned on to 'always'. How about "Background app refresh"? Is that setting required? Any other iOS settings I need to setup for an optimal Scenic app experience?
Scenic only requires "Always" location access if you use Scenic in the background (with other app in foreground or iPhone locked) while navigating / recording a ride.
"Background app refresh" is not required.
You could set the "Use cellular data" (in iOS Settings > Scenic) to OFF if you don't want Scenic to use cellular data. Make sure you have the offline maps installed though. And...with cellular data off, and not on WiFi, below features are not available:
  • Curvy route generation (already saved (curvy) routes are fine though)
  • Online HERE search
  • Google Search
  • Apple Search
