Automatic stop function for break and re-filling
Hi guys,
I’m using Senic for quiet some time. That means for routing and planning purposes. What I’m struggling with is to find the wright time for breaks and for re-filling my bike.
would it be possible to have an option at the planning phase, where you set time or distance between rest points and something similar (but then mainly distance) for re-filling? You don’t have to pic a Rest area or petrol station, but an indication (Stop point) for planning purposes would be extremely fine.
This function might be already available, but I wasn’t able to find it.
next step could be to select rest areas and petrol stations.
regards Uwe
Understand what you mean. I will add this to the list for Scenic 3. It will not be in there from the beginning, but this is a highly requested feature so it will be added.
thanks for considering the change in the next version. Is there already a due date by when Version 3 can be possibly downloaded?
Cheers Uwe
Hi Uwe, here is all information I am sharing about Scenic 3 at the moment: https://scenic.app/knowledge-base/scenic-3-info/
Did this ever get added, I've looked but can't see a way off adding a stop point at a specific mileage or time am I missing something
thanks
I haven’t found the time to add this yet. Sorry.
converted has reacted to this post.
converted
Quote from Guido on 20.09.2024, 11:37
would be great to consider it for the next time. But maybe a step in between would be a stop time for better planning. I mean the time that I plan to rest at one stop.
Uwe
Hi Converted.
Some had this request before, me too. As long as it isn’t implemented i plan my routes and add 1 hour, or with larger groups 1 1/2 to my arrival time.
In unknown regions it make sense to add 2 hours, deviations, roadworks or spots and poi‘s where you do a longer break.
3 weeks ago we went to France, time for check-in at the hotel: 17.30, i planned to ride till 16.30. Small group, 3 people.
This workaround does it till Guido finishes the break function.
Kind regards, Mex
converted
Quote from Mex on 21.09.2024, 23:32
Hi Converted.
Kind regards, Mex
Hi Mex,
thanks for the idea. I’m using something similar in the meantime.
Kind regards Uwe
