Auto Zoom Speed
Quote from PeteRT on 21.04.2022, 10:39Hi Guido
I have been using the app a lot recently and it has been performing really well. I have the Auto Zoom switched 'ON', so the zoom of the map changes with speed. Is it possible to have a method of being able to change the rate the zoom occurs. When I am approaching a turn / junction it would be nice to have the junction zoom 'IN' quicker. When stationary it's perfect but then it is too late. I know I could use manual zoom buttons but I don't like interacting with the app in this way when riding. Maybe there could be a way to select a distance to turn for full zoom in so about 1/4 mile, so you can get a heads up of a complicated junction before you get there. At the moment it is perfectly workable but if it is possible then a tweak to the auto zoom would make it just that bit better. Obviously after all the other 101 requests you get.
Really liking the ability to customise the colours. Funny how for me that makes the app so much more readable and so enjoyable to use.
Hi Guido
Quote from Guido on 21.04.2022, 10:45Hi Peter,
At the moment Scenic uses the built in Auto Zoom feature that is provided by HERE maps. It's speed based, hence the delay you are experiencing. I'm planning to add a custom zoom feature dependent on Distance To next Turn, but that's quite some work. It will be a while before I get around to that because there are many things on the list still.
Perhaps what you could try (if you use the map in 3D mode) is change the 3D camera angle (Settings > Finetuning). Not exactly what you are looking for, but perhaps it will help.
Happy you like the custom map styles 🙂.
Hi Peter,
