Forum breadcrumbs - You are here:Scenic ForumScenic Feature RequestsAudio check
Audio check
Is it possible to add an audio message to the voice on/off button in the menu? With a message when you turn it on, you immediately know whether communication with the headset is working and you no longer have to wait for the first turn. Thanks, Geert-Henk
Hi Geert-Henk.
Before you start your ride just tap the symbol on the upper left side of the screen. When your headset works you get the instruction by voice-command.
Turn right in 2 miles e.g.
Normally that should do it, or did it in the previous versions.
Actually tried it, while in my garage, and: didnt work! 😜 Oops.
Just give it a try.
Regards, Mex
Hi Mex, That would be nice! I tried, but unfortunately it doesn't work (yet).
I'll add the audio message when turning voice to "ON" or "Alerts Only".
Tapping on direction arrow to repeat last instruction indeed has not been implemented in the update.
GHJ has reacted to this post.
GHJ
Hi Guido.
Today i went by car and tested it.
While navigating and tapping the direction arrow will repeat the last instruction.
This worked last year as well.
Regards, Mex
My way of checking if the helmet is connected is to go to navigation, then open the menu and tap on louder then a tone is played, but you're right , another button that just counts 1-5 or something as check would be better.
BR
Mario
