Question: Where do you usually make and carry out the routes, what programs do you usually use?
Hello, I would like to know when you set up a route where you do it on your PC or mobile and what programs you like best to do it with.
For simple routes I plan directly in Scenic.
For more complicated routes, I use Google Maps, and then import the route into Scenic: https://scenic.app/help/import-from-google-maps/?seq_no=2
jordi honrubia has reacted to this post.
jordi honrubia
Why?
Is that because you use PC and then have the Google map on a bigger screen with mouse compared to the (a bit clumsy?) iPhone or iPad touchscreen?
I use MAC and plan my fairly complicated routes in Scenic. Did not miss anything up to now..
Johan
jordi honrubia
Thansk @johansw. That's a good addition.
If you have a Mac, Scenic will run on that too. But only if it's a Mac with Apple Silicon processor. It will not run on older Macs with Intel processors.
jordi honrubia and Marts have reacted to this post.
jordi honrubiaMarts
That's why I asked the question, because I have a PC, I don't have a Mac.
Using Google or a myroute account that I like but I thought that maybe using other applications is impossible for me with the mobile screen.
If possible I will use a PC and Furkot.com.  The import into Scenic has been flawless and the premium features of Furkot.com for $14/yr are fantastic. Multiple day routes all done in one planning session are great and the best feature has been finding food places before getting on the road; I have found some great hole-in-wall places that have turned into real gems.
jordi honrubia and mcouture have reacted to this post.
jordi honrubiamcouture
For detailed routing/planning, especially multi-day plans,  I use http://www.furkot.com.
Importing into Scenic is quick and easy.
jordi honrubia
Genuine dinosaur here. Workflow at present 1) 20year old Michelin map. 2) Google street view to have a closer look at some specifics. 3) direct to Scenic on this iPad mini4  4) suit up 5)ride.
l have just completed planning three weeks, Andalusia. On the fly edits, re plans are easy, normal. Years ago, having followed a snow plow off the mountains I sat with coffee, reworked all routes around the Storm. Paper and iPhone.
jordi honrubia
Shorter routes I plan with Scenic and as a former Garmin User I use Garmin Basecamp for more complicated routing and for organising my routes and tracks.
jordi honrubia
I use the German web app Kurviger.de
I started to use Kurviger.de some years ago when I still had my old TomTom Rider. Initally TomTom had promoted the development of the online planner TYRE, but apparently this connection has become lost, so I got an Kurviger account. Kurviger allows to create optimized routes and export them in various file formats.
Last year I sold my TomTom and started to navigate using my iPhone and Apple Carplay. I found out that Kurviger offers a direct path to export a route to Scenic, so I got a Scenic license.
jordi honrubia
Quote from jordi honrubia on 04.03.2024, 10:49
I use Google Maps, create the route, then copy the URL into Scenic's web App. That imports it into the app.
I also use the My Route App website. I'll create the route, save it and export it (using the "save as" function) to a GPX file which is saved in a folder on iCloud Drive.
iCloud Drive is accessible to all of my Apple devices, so I can load up routes as needed. I then use Scenic's import functions to import the GPX files.
The great thing about Scenic is being able to create folders in which to store routes. I have created a few to separate private rides from group rides.
jordi honrubia
Quote from Guido on 04.03.2024, 11:51
Hi Guido.
I've just installed Scenic on my Mac Mini M2 Pro. It works well and the Power Planner is SO easy to use on the Mac with the 32" screen.
However, and this for me is a big one, its default location is Cupertino, USA. I'm in Australia.
I have location services and all that working (Google Maps knows where I am). How do I get Scenic to centre on where I am?
Martin
This is a bug that will be resolved in the upcoming update.
For now, what you can do to resolve the problem, is tap the "start ride" button. I know it won't do anything, but it will store your location and center on that one next time.
Thanks for the quick response, Guido.
Yep, that's  fixed it.
Talk about top-rate support.
Quote from Guido on 11.03.2024, 18:09
I'm now learning how to use Power Planner now that I can plan rides from home. One thing that it's not doing for me is to either zoom in or out to more precisely insert Via or Stop points.
Can the map be zoomed when running on a Mac?
Hold command key and then use mouse scroll wheel.
If you have a trackpad, you can pinch zoom with thumb and index finger, or hold command key and make scroll gestured (usually move two fingers up or down on the trackpad).
I know that the command key + scroll wheel / scroll gesture jumps the zoom in too big steps. That will also be fixed in the next update.
Marts
Quote from Guido on 11.03.2024, 18:31
Ah, great!
Am now planning a 600 km ride that we're doing in two weeks' time. Learning how to use the via points including changing the route between via points using "Via X".
Thanks again for your continued developer support. It's fantastic!.
jordi honrubia
Thank you for the answers to everyone, I like it and I quote myself because this question that helped me I also know that it will help me several, knowledge does not take up space.
Late to the party but I am another user of Furkot.  It workes very well with Scenic.  It had a "kind of" steep learning curve but now I can whip out a route exactly the way I would want to go and it uploads without a problem.
Michael "BONES" T.
