Another small bug
Quote from CB1100_Tom on 17.12.2020, 09:51Hi Guido,
there's another small bug I found. if your'e not loading the phone, the battery indicator in portrait mode is white. Changing it to landscape the battery indicator turns green, as if it's being loaded. So in landscape mode you don't know if the battery is being loaded or not.
Also it would be great if you could see the cell phone connection info just like in portrait mode. LTE, 3G, E.. and the signal strength.
Quote from Guido on 17.12.2020, 16:22It looks different in landscape because iOS hides the status bar in landscape. When loving to landscape I add the custom battery symbol to the screen.
And... When connected to a charger it will show the lighting symbol inside the green battery. I will see what I can do to make this more intuitive in Scenic 3. (Understand the confusion regarding the standard status bar color and green color).
Quote from CB1100_Tom on 18.12.2020, 06:40Okay, sounds good.
what about the net Info and the Field strength? Is it possible to add that too?I thought the top and bottom white bar comes from the App. 😳
Is it possible to make the top white bar transparent? In landscape mode.
Okay, sounds good.
Quote from Guido on 21.12.2020, 16:07Well... I can force the status bar to show, and even make it transparent, but it would take up some space (height) which is already scarce in landscape mode. Let me see what I can do for Scenic 3. I might redesign the landscape navigation mode all together.
