amazon music / garmin zümo XT
Hello Guido,
Version 3 is just great! I have two questions 😉
1. Would it be possible to integrate Amazon Music? Operation and mute announcements?
2. I had exported the gpx file and wanted to import it to the neighbors via this horrible garmin basecamp. I didn't succeed. Only when I imported the gpx from kurviger.de and then exported it from there. The background is that I usually ride at the back of the group and the first ones don't have an iphone, but have super great garmin devices like the zümo XT.
All in all everything is going great at the moment. If you are still looking for testers for carplay ....
greeting
Micha
keep it up !
I have no problems importing exported routes from 'Scenic' into Base Camp. If you import the scenic GPX file you get the start and end point, two routes (that are indeed useless, because they ar only a direct line fram a to b) and a track which is showing the exact route.
I didn't succeed.
What is the exact problem you or your the group members have?
Hi Micha,
There is a way that Scenic can operate all music/player apps (basic functions at least): https://scenic.app/help/control-music-playback-for-all-media-apps-not-just-apple-music/
As for the GPX, like @massi mentioned, the GPX should contain enough info. 2 routes and 1 track. The routes (one of them anyway) is specifically for Garmin devices. You (or rather your Neigbour) might even get it on the device through one of Garmin’s apps (I believe it’s called the Drive app), without using basecamp. You’d simply have to send the GPX to him/her and they take it from there.
Indeed I’m not sure the routes are useful in basecamp. You’ll probably get better results with the track in basecamp like massi mentioned.
I had a closer look to it and one of the two routes is useful, it is the route with the profile "direct", it shows real waypoints connected with a line, if you choose another profile, like "motorcycle", Basecamp will calculate a new route with pay attention of the waypoints. It is not a 100% exact route but very close to it, you can correct it with the help of the track. Another possibility is to let calculate a route from the track with "Basecamp".
The route would be more accurate if "Scenic" would create more waypoints or better "shaping points", because AFAIR "Basecamp" can only handle 15 waypoints per route, while routes can have 150 shaping points.
The second route is only a line between start and end point, without any via- or waypoints.
@massi what must i do in basecamp to use this route for example ?! https://scenicapp.space/viewRoute.php?rid=GgWhSyGO
I made a little YT Movie, perhaps it helps.
