Forum breadcrumbs - You are here:Scenic ForumUsing ScenicAmazon Music
Amazon Music
Can anyone please help me, the help pages show a method of allowing apple shortcuts to be set up for Amazon Music use through Scenic. When following the instructions on my iOS 16.0.2 enabled iphone I get no ‘allow untrusted shortcuts’ option in ios settings app > shortcuts. Has this setting been changed by Apple or have I missed something?
Indeed this options seems to have been removed in iOS16.
Do the shortcuts work though, even though you don't get the option to 'allow untrusted shortcuts'? For what it's worth, they still work here on my side, but I already set them up while still on iOS15.
it seems not for Amazon music, infact I can not set any shortcuts up for Amazon Music as it does not show in the shortcut app.
I have managed to use shortcuts successfully for setting up the two navigation menu links in Scenic, but this was to activate an app called Realrider which did appear in Shortcuts.
😳 It seems its user error at the heart of the problem!! Yes Apple has removed the “allow untrusted shortcuts” but this step seems not be needed any more, when I followed the rest of your instructions correctly, it worked perfectly! So embarrassing 😳. Great app, loving it more and more as I get used to it and thank you for taking the time to reply to me. 👍
No Problem. Did you know you can also set the 'previous', 'play/pause' and 'next' buttons in the navigation menu to control any audio app (incl amazon music)? It also works through shortcuts... to activate that go to Settings > Navigation Menu > Playback control
Reply101 has reacted to this post.
Reply101
