Alternative routes like in Waze
Waze has a neat feature where you can quickly choose an alternative routing in case you want to try something different. It would be really cool if Scenic could do something similar, without having to enter vias or use the power planner. Often there are alternative routes that use completely different roads and are just marginally longer / slower - so using the selector between fast/short/balanced doesn't show these alternatives. I can give you some concrete examples if you are interested.
Mark
Hi Mark,
I understand and know the concept. I’ll add this to the list, but it will have to wait until a major scenic update as this is quite some work to implement. I’ll combine it with other bigger changes.
cheers,
guido
marcom has reacted to this post.
marcom
