Alternate route
Quote from serge.beukers on 22.02.2021, 09:01Hello @guidomm
Is it possible to let de app suggest an alternate route.
Example:
Let the app create a route to a city, generate a curve route, it gives back 1 route, always the same route. Every day.
The request is to generate an alternate route, when you choose it it will generate a new (curved) route, different roads, every time when you choose "alternate route" is should gives alternatives to choose from.
Like TomTom. (sorry)
Hello @guidomm
Example:
Quote from Guido on 22.02.2021, 09:11At this moment that's not possible. I'm dependent on Scenic's Curvy routing provider (Kurviger) for that. What you could do is one of two things:
- play a little bit with the curvy routing settings (change from 'curvy' to 'extra curvy' or turn on some avoidances)
- add a via point before you generate the curvy route. The generation will make sure you pass that via point and thus the entire route has a chance of being different (if that via point was not already on the 'normal' curvy generated route.
hope this helps.
hope this helps.
