Adding Via's and options while creating a new route on the map view
I don't know if its exists, if it does I could'nt find it. (I'm sure this is possible with the powerplanner, but my suggestion is to add it in the 'kaart' view)
When you are on the 'map/kaart' screen and you want to create a new ride, you can only search for a address and do the route to that one location.
I would suggest a 'add another destination' option, so you can create easily a simple route with 2-3 via's. Also it would be nice if you can change the route options for each via/destination.
It’s possible. After adding the final destination, simply select or search for another place and Scenic will ask you this:
hhk1907 has reacted to this post.
hhk1907
