Adding a Favourite to a route and display a Stop marker on a Favourite
I am having trouble adding a waypoint at a Favourite point, this may have worked differently in the past.
  1. I have a Favourite at Aiken Road and if I short tap on it a dialog shows the Name. It would be great if I had an option to Add it as a Stop or Via.
  2. When in Route Edit mode and I place the cross hairs on the Favourite and hit Stop# and it creates a Stop called Stop 2. It would be good if the Stop name was the Favourite name. I also have to be very precise on the cross hairs being on the Favourite.
  3. Also if a Stop or a Via is on a Favourite it can't be seen unless Favourites is turned off. Could the Stop / Via marker be visually added on top of the Favourite Marker?
In the display below there is a Stop but it cannot be seen
Thanks Guido
I understand. Have added this to the feature request list.
  1. When in Route Edit mode and I place the cross hairs on the Favourite and hit Stop# and it creates a Stop called Stop 2. It would be good if the Stop name was the Favourite name. I also have to be very precise on the cross hairs being on the Favourite.
That won't be necessary anymore after I implement the first point (then it will take the name of the location automatically)
  1. Also if a Stop or a Via is on a Favourite it can't be seen unless Favourites is turned off. Could the Stop / Via marker be visually added on top of the Favourite Marker?
That's an easy one. Will fix that for the upcoming update.
Old Man Emu
Love ❤️ your work Guido.
