Add no interstate highways
One thing I’ve asked of all mapping providers I use is to change the no highways feature to no interstate or autobahn or some other method. Most of the programs are to literalist  when selecting no highways. The app takes you on goose chases around towns to stay off the highway one is already on when entering the town. Anyway, there may be a reason for the problem, but it makes routing difficult.
I understand. Unfortunately this is mostly out of my control though. It's the map that Scenic uses that provides the 'avoidances'. You might want to give curvy routing a try. There is an 'avoid highways' feature, but also an 'avoid main roads' feature. In the end it depends how roads are classified in the map data of course. Lastly, there's always the option to manually create your route with the power planner of course. I know this is probably not the answer you were looking for, but I hope it at least explains.
Thanks, while I sort of don’t expect you to do this and I understand the limitations the systems you use put on you. I’ll try your suggestion.
