Add next gas station
Quote from Toku75 on 08.06.2020, 19:46It would be nice if it would be possible to add the nearest gas station to the current track by just one click and go on with the modified route.
I'm not even sure how to do this with the current functionality and more than one click. If I start navigation and add a stop for a gas station, the whole route is gone and I only see the navigation to the newly added gas station. I'd expected that Scenic will just calculate an indirection to the new stop and keep everything else. I'm absolutely new to Scenic and am just trying from the couch. Am I doing something wrong or is this not possible?
Quote from Guido on 08.06.2020, 19:56Hi Toku,
It's not a one tap action at the moment (will be added in the future), but it is possible:
- While navigating, move the map a little bit -> you'll go to edit mode
- Now tap 'search' button bottom right
- Then tap 'gas stations'... that will show gas stations in 10km radius of your current location
- Tap on the one you want to go to and then select after which stop you'd like to insert it
Hi Toku,
Quote from Toku75 on 09.06.2020, 02:03Hi Guido,
many thanks! With the new version this is working fine.
By the way. Did you really want to remove the separate alarms for inside and outside of the city in the new version? In the older version I could select two different thresholds.
Best Regards,
Tobias
Best Regards,
Tobias
Quote from Guido on 09.06.2020, 04:48Hi Tobias, turns out the outside threshold had no effect. It was using the inside threshold in all cases. This is a framework bug which I can’t fix, so decided just to make one threshold of it.
