Forum breadcrumbs - You are here:Scenic ForumUsing ScenicAdd Gas Crash
Add Gas Crash
Hey Guido,
If you’re already aware of this one, please ignore.
When tracking a ride and you use the gas button from the menu and try to add a station to the route, it crashes the app every time for me.
Hi Chris,
I wasn’t aware of this. Is this with v4.01 which was released earlier today?
Thanks and regards,
I didn’t notice it happening before the update, but yes, definitely after I downloaded v4.01.
I just tried to reproduce it but it’s not crashing for me. I will have received the crash reports and will investigate. Thanks again for letting me know.
Ok, if you do it by long pressing one of the locations on the map and add to route from there, it does not seem to crash. But if you choose a location from the list of options then add to route from there, it crashes. Just tried again.
Still can't reproduce. Here's what I'm doing to try and reproduce. Am I doing something differently?
  • Start Scenic
  • Tap "ride" button (so... I am not navigating a route... but also tried that)
  • Go to "navigation menu" and tap "fuel pump" button
  • A list of fuel stations appears and are show on the map
  • I select one of the markers on the map, or I select one from the list (doesn't matter)
  • I tap the "add to route" button in the callout bubble.
  • Now I see a route from my current location to that gas station.
  1. Hi Guido
I’m getting what I think might be the same problem, but when I use either the auto zoom setting or map direction setting in that menu.
I’m on the new version released today, and can replicate the problem.
Here’s a video: https://1drv.ms/v/s!AkNU6n7k7sKwia5qSgumns8_t0aHWQ
Don't think that's the same problem, but I'll take a look at this one as well.
PuddleDuck has reacted to this post.
PuddleDuck
Hm, interesting that now it doesn’t seem to be crashing the app every time.  Before I called it out it was literally happening  every time.  I’ll keep testing and try to isolate the behavior further.
Thanks Guido!
I tested this while riding today and the app crashed on me once, but didn’t reoccur again.
