Add "Back" Button on search results on map
If I search for e.g. gas stations, all search results are displayed from nearest to farthest. Once i select one of those results and I see on the map that I don't want that one, I have to start the search all over again. Thats even more annoying if I entered a long address and recognize I did a typo after seeing it on the map.
So could you include a "Back" button when the search results are displayed on the map? And even better a button to restart the search if one moves around the map, so you get the gas stations for that area without having to start allover again.
And also could you show the calculated distances to the gas stations not only in the results overview but also if I click on a result on the map?
Since the data is available anyway and it helps to evaluate if one can make it to the chosen gas station...
Thanks, David
I have some improvement in mind, along similar lines, but not 100% what you are suggesting.
What I want to do is have a search history. So when you tap 'Where to' in the search screen, you'll get a drop down of recent searches. I think that is more in line with main stream navigation apps (and even other apps with searches), and also solves your problem (in stead of 'back' button).
Btw... did you know you can tap this button to show all search results on the map at once?
That button is exactly what I was referring to.
When I press it, all of the search results are shown on the map, which is great! But after that, I can't get back to the results page where I can see the distances.
OK. So you'd like to see the distance in the callout bubble? Will add to list.
Yes exactly, if thats not too complicated to do.
Having the back button in addition would be even better, I think!
In case one chooses a gas station in the results summary and just wants to have a look where the chosen gas station is on the map, but then decides for a different one and thus wants to go back to the screen with the search results. It just makes the whole process much faster and more user friendly.
Hola
I’m sorry. I don’t understand. Where would you like the back button?
After clicking this button:
all the search results are shown on the map. But then I have no way to go back to the search results. So I would want a Back button when the results are shown on the map.
So something like this:
sarod has reacted to this post.
sarod
Ok. Gotcha! Will add to list! Thanks
Thanks! 🙂
