Forum breadcrumbs - You are here:Scenic ForumUsing ScenicAdd and Stops
Add and Stops
This might be a stupid question but what is the difference between "Via" and "Stop"? When do you use via and when do you use stop? I just wanted to know if I am using it right to take advantage of the features in this app.
During navigation you gat an audible and visual notification when you approach a stop. For vias you don’t get that.
Also vias might be removed when you detour and the route is recalculated.  See the descriptions under Settings > Navigation & Tracking > detour behaviour.
