Add all locations from a folder
Quote from botzko on 12.11.2021, 11:06Hi Guido,
When I use the import function there will be the route/track and locations. I will import all locations I need in a new folder. After this will import the route and will add these locations. The problem is that I need to add them one by one. Could you consider implementing adding a folder or allow multiple locations to be selected and added at the same time?
Kind regards.
Kind regards.
Quote from Guido on 12.11.2021, 11:25I'll add it to the list. However, I would expect the route in the GPX to contain stops where the locations (waypoints) are as well? eliminating the need to add each location to the route manually.
Quote from botzko on 15.11.2021, 02:53Hi Guido,
excuse me but I didn't understand the question. In most cases I will have a route exported from Google Maps (via external services) and this route contains multiple stops. On Google Maps they are with letters
A,Band so on. When I import this route I will see the stops in theImport Locationsection and they will not be imported as stops in the imported route (even if I have selected to all of them before I click the button to import the route). I will be able to upload screenshots next time I need to import a route if this will help.Kind regards.
excuse me but I didn't understand the question. In most cases I will have a route exported from Google Maps (via external services) and this route contains multiple stops. On Google Maps they are with letters A, B and so on. When I import this route I will see the stops in the Import Location section and they will not be imported as stops in the imported route (even if I have selected to all of them before I click the button to import the route). I will be able to upload screenshots next time I need to import a route if this will help.
Kind regards.
Quote from Guido on 15.11.2021, 04:40Are you using the Google URL import function of the WebApp for this? https://scenicapp.space/webapp.php ?
Quote from botzko on 15.11.2021, 04:50Nope. I forgot about this one. I will report next time when I receive a route that needs to be imported. If I still have a problem I will update the file.
Kind regards.
Kind regards.
