Ad-how curvy route
Quote from clarkml72 on 07.06.2025, 13:53yesterday, I tried to create a curvy route from one city to another with the curvy setting. as you can see from the photos below this type of creation still has a mind of its own like it’s possessed or on crack.
why does it take me or wish to take me through parking lots or residential neighborhoods? When rerouting it’ll do this too luckily I can see the route goes, but when this happens over a broader area at my zoom level, I’ll take where it tells me to go only for to say turn around now.
this has been an issue since version four and it’s still an issue in 4.18.
extremely frustrating
Quote from Guido on 07.06.2025, 14:14I’m working on improving this.
this is a great test case. Would you mind sending me the start and end coordinates of this route (and of any stops you placed manually, if any)?To get coordinates, edit the route, tap on marker, and select “copy coordinates” and then DEC.
And also a screenshot of the curvy routing settings you used.
Quote from clarkml72 on 07.06.2025, 18:02[caption id="attachment_9282" align="alignnone" width="369"]
Start Point: 34.879304,-83.396516
End Point - 34.875450,-84.243476
About 78 miles...
I re-created the route and each time I do it new the "same" locations dart off into businesses, driveways, or parking lots...
Thanks man
Mike
About 78 miles...
Thanks man
Mike
Quote from Guido on 08.06.2025, 13:34Found something. Will be improved in upcoming update. With a bit of luck will be released before next weekend.
