183km route in Google Maps becomes over 1,000km in Scenic.
Quote from Clarky on 22.06.2021, 08:49I know that when I copy and past URL from Google Maps into Scenic WebApp it can do some strange things. But this one is beyond me and I really don't know where to start to unravel it. My route in a couple of weeks time shows as 178km in Google. Fine. A gentle cross country route with my wife. 3 Hours or so in fine Spanish weather.
However, When I past the URL into Scenic it turns into a 1,431 marathon via Madrid with 117 Vias. .
A few small routing errors and loops I can cope with but this would try my patience if I had to do this everytime.
I chose Scenic about three years ago because of its great interaction with Google Maps but for various reasons have not been able to use it much.
Any advice anyone?
Steve
Any advice anyone?
Steve
Quote from Guido on 22.06.2021, 09:20Hi Steve,
In google maps, in the panel on the left, where you enter the stops, there are typically the names of the places. Sometimes these names are ambiguous. I.e. there are two places with that name. If that's the case, sometimes Scenic gets a different search result (the "other" one) for that name. My guess, without seeing the actual route, is that this is what's happening here. To work around this, in Google Maps, move the markers corresponding with those stop a little bit on the map, so that the name in the panel on the left changes. Then import that URL into Scenic.
I am working on a better solution for this, but Google is changing the URL structure frequently and it's quite some work to reverse engineer this, so that's going to take some time.
Sorry about the inconvenience. If there's anything else, please let me know.
Best regards,
Hi Steve,
Best regards,
Quote from Clarky on 22.06.2021, 13:28Thanks Guido. I’ll try that tomorrow. I’ve installed Google Maps on my laptop rather than use maps in Chrome and that seems to have helped.
One more question if you don’t mind. (I’ve just retired so now have more time to ride and use Scenic😬, so more questions)
Voice navigation. It works well on the phone and through the BT headphone. (Interrupting music or whatever I’ve got playing).
But if I’m chatting with my wife as pillion on intercom it gave me navigation instructions but then it wouldn’t automatically close and put us back together.
Any suggestions?
Any suggestions?
Quote from Guido on 22.06.2021, 15:19Voice navigation. It works well on the phone and through the BT headphone. (Interrupting music or whatever I’ve got playing).
Any suggestions?I understand the problem. You are not the first one. It depends on the headset you are using the ‘priorities’ you set for the headset (intercom higher priority then music, phone call higher prio than intercom, etc). With some headsets this is configurable, other not. Sena’s have more problems then Cardo’s overall.
From Scenic perspective you could try to set voice output to ‘as Phone Call (HFP)’. Sound quality of instruction will be less but might get you intercom back after playing instruction.
Any suggestions?
