You can find the Scenic Bug Tracker here.
You only have ‘view’ access, but you can search, sort, and filter the list with some limitations:
  • Search with [cmnd]-F / [ctrl]-F
  • Filter by using the button circled in below screenshot.
    • There is a pre-defined filter that sorts the bugs by Kind, Status and Prio.
    • You can create your own filter by choosing ‘create new temporary filter view’ from the dropdown menu.
      E.g. to filter on your name in the ‘Tester’ column.
